boundary vertex check
Hello everyone
do anyone know where can I make "boundary vertex check=f"? I get an error and the suggestion is to put "boundary vertex check=f" but I can not find it in expert parameter. please let me know the exact root of it. thanks for help |
You put it in as an expert parameter.
But these expert parameters are rarely the solution. You have some fundamental error with your model (which the error is picking up) so you should fix the fundamental problem, not try to kludge it to work anyway. |
I use Ansys v14.0 and didnt find it in expert parameter tab. How can I put it in? thanks alot |
No, not a subroutine. An expert parameter.
You will probably have to add it to the CEL as it might not be on the CFX-Pre GUI. |
