Setup of a turbine stator blade conjugate heat transfer simulation |
February 7, 2014, 04:53 |
AGNIMITRA
Hi!
My objective is to carry out a very simple conjugate heat transfer simulation and obtain a temperature distribution on a stationary blade surface. 1)Blade surfaces and the end walls have been given as adiabatic walls. 2) I have not initialized the solid and fluid domains. 3)I have set a conservative interface flux near the interfaces. Is it because of the ADIABATIC WALL condition that i am getting a constant blade temperature distribution all over the blade??? I feel there is some issue in my understanding of the numerical setup of the problem. In the solid domain : heat transfer I have set the thermal energy option . Is it correct? Please , if possible read it and Guys please point out the silly mistake i am making. Thanks!!! mitra Last edited by mitra22; February 7, 2014 at 06:16. Reason: specified irrelevant details |
boundary conditions, fluid structure interface |
Quenching simulation : how to set up a conjugate heat transfer between solid&liquid | Rockda | FLUENT | 24 | August 30, 2016 06:33 |
CFX conjugate heat transfer problems | dingsheng1206 | CFX | 7 | February 13, 2014 13:29 |
Heat transfer simulation in electric motor by using fluent | thuanckdlvn | FLUENT | 1 | March 20, 2013 06:32 |
Conjugate heat transfer | kiteguru | CFX | 2 | January 9, 2012 15:57 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 22:22 |
