Home > Forums > CFX
how can I improve the y+ value?
Old   February 22, 2014, 18:22
Default how can I improve the y+ value?
Madelaine
Madeliz is on a distinguished road
Hi, I'm working on a project that involves wind generation with a diffuser augmented wind turbine. I would like to know how can I improve the y+ value on the diffuser. It presents a value of 533 aprox on the y+.
Madeliz is offline   Reply With Quote
Old   February 22, 2014, 19:25
JuPa's Avatar
Mr CFD
JuPa is on a distinguished road
There is a lot of literature which explains the definition of Y+. Here's a start:
http://www.cfd-online.com/Wiki/Dimen...tance_(y_plus)
It is a dimensionless wall distance. It is particularly important in turbulence modeling close to walls. High speed flows close to a wall produce higher Y+ values. The Y+ value you need depends on which turbulence model you use (if you're using one).
You can estimate how big or small your first cell height should be to obtain your desired Y+ by using tools such as this:
http://www.cfd-online.com/Tools/yplus.php
In your case if you want to reduce your Y+ you need to refine the mesh closer to the walls. After you've done this re-run the simulation on the refined mesh, and check the Y+ values again.
Just remember if as you refine you also increase the number of elements in your mesh and greatly increase the simulation time. Hence don't refine unless you have to. This goes in hand with a mesh sensitivity study.
JuPa is offline   Reply With Quote
Old   March 30, 2014, 10:56
Madelaine
Thank's a lot it works but I have a question now as you can see at the picture it presents an irregular result around the rotor section is that ok?
Old   March 30, 2014, 18:05
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
This generally indicates a coarse mesh. Higher than intended y+ also results from coarse meshes. The solution should be obvious.
But as for whether your current mesh is OK - do a sensitivity check and find out. You cannot tell from just an image.
Thread Tools
Trackbacks are On
Suggestions to improve result Davide_sd FLUENT 0 June 29, 2013 09:26
How can I improve my residuals tstensrud STAR-CCM+ 9 May 14, 2013 22:34
Question about coarsening the mesh to improve convergence Anna Tian CFX 9 August 13, 2012 14:53
How can CFD be used to improve race car? A Chu FLUENT 1 February 8, 2004 21:21
How to improve Velocity magnitude ravi FLUENT 0 June 23, 2003 13:17
