Transient solution, variable does not change with time
Old   February 28, 2014, 04:37
Default Transient solution, variable does not change with time
Jamie
JMOP is on a distinguished road
I am attempting to determine the frequency of vortex shedding of a nozzle. The fluid is water. I have set up a steady state solver to provide the initial conditions for a transient solution. The solvers run concurrently and were set up following these instructions.
http://www.ansys-blog.com/multi-conf...te-simulation/
Both the steady state and transient cases are run using Shear Stress Transport as a turbulence model.
I set the time interval to give me a courant number of 5 and ran the transient case for 500 time steps. In the results window I inserted a point just downstream of the nozzle and created a chart of pressure against time. Apart from an initial fluctuation, pressure settles to a value and remains unchanged. I get the same result if I plot total pressure. The steady state solution shows eddy viscosity to be in the order of 0.38Pa S downstream of the nozzle, so I am minded to think that there would be some pressure fluctuation. Can anyone advise me as to what I might be doing wrong?
JMOP is offline   Reply With Quote
Old   February 28, 2014, 14:57
The basics are covered in an FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
strouhal number, transient analysis, vortex shedding
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
Time accurate vs Fast Transient Solution pritam.edke Siemens 0 June 18, 2012 14:57
Creating Table of Variable versus Time in Transient simulation in CFX 11 cjhaw CFX 2 January 15, 2011 11:52
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
