Home > Forums > CFX
Experiment - CFD Result Differences
Old   March 3, 2014, 11:56
Default Experiment - CFD Result Differences
Leifheit is on a distinguished road
Hello everyone,
I have been trying to verify some results I gained for a 2D simulation of an airfoil.
To do this, I compared the plots of the lift coefficient over angle of attack of experiment and CFD results. For low angles of attack, everything is fine. At higher angles the results differ quite a bit though.
Do u have suggestions how to solve this problem ?
I already tried
using different turbulence models (currently using SST)
using more/less refined grids
I attached the lift coefficient over angle of attack plot.
If u need any additional information please tell me.
My final goal is to run simulations with a much higher Reynolds number. There do not seem to be any experimental results for those.
Do you have suggestions how to ensure my results will be valid ?
I would perform a mesh refinement study and also use an appropriate turbulence model. Are there any other things i could take into account?
Best regards,
Leif
Leifheit is offline   Reply With Quote
Old   March 3, 2014, 17:30
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
RANS is often not suitable for modelling in the stalled region of flow. You probably need a turbulence model from the LES family, such as SAS, DES or full LES to model it properly.
Old   March 5, 2014, 11:35
thanks a lot for the fast reply !
Do you think the results I attained are comparable to what other people gained from RANS ?
Also do you have any suggestions as to how to change my simulation setup for the usage of higher velocities ?
Best Regards,
Leif
Old   March 5, 2014, 17:34
Your results look pretty typical for RANS simulations - pretty good in the attached flow region, but a bit off in the stalled region and the stall point is not quite right either.
Thread Tools
Trackbacks are On
validation of CFD and windtunnel experiment M.Arun prasad FLUENT 4 March 13, 2008 03:12
Wall shear stress lagha FLUENT 2 May 31, 2002 13:18
help:negative entropy appears in cfd result rb Main CFD Forum 6 October 27, 2000 00:14
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
public CFD Code development Heinz Wilkening Main CFD Forum 38 March 5, 1999 12:44
