single phase analysis using CFX
I want to do single phase simulation using CFX.
How can I do? |
This should help you out greatly: http://www.cfd-online.com/Forums/cfx...ease-read.html
I appreciate your advice.
I will ask you again. I try to analysis of flow characteristics in vertical pipe for urban drainage using CFX. And I will compare the difference between single phase analysis and two phase analysis to verify the effects of the air. But, I don't know how set up CFX for single phase. I know that CFX set up multi-phase basically. Thanks.:) |
Have you done the tutorials? Your single phase simulation sounds like very basic stuff and that is well covered by the first few tutorials.
You can find the tutorials in the Help menu, under tutorials. |
Do ALL of the tutorials. Even if they're not applicable to your problem, do ALL of the tutorials.
