Home > Forums > CFX
Radial Turbine
Old   March 8, 2014, 07:01
Default Radial Turbine
Ali Can İspir
alican9547 is on a distinguished road
Hello dear friends,
I design a Francis Turbine in ANSYS. I used Bladegen. In CFX Solution Section, I see '' A wall has been placed at portion(s) of an OUTLET boundary condition (at 35.7% of the faces, 19.9% of the area) to prevent fluid from flowing into the domain.''
I did some searches and found a solution which is usage of opening type boundary condition in this forum and saw how to make opening boundary condition. I defined Total pressure for flow entering the opening and Static pressure for flow exiting the opening in setup section. But it did not solve and I don't still understand that how can I define my flow rate when I define this. There is no option to define flow rate at the opening boundary condition.
I calculated that the efficiency is approximately %98. How can I prevent the solution putting the wall there? Can the wall affect my results so much?
Thanks...
alican9547 is offline   Reply With Quote
Old   March 9, 2014, 06:35
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
The "A wall has been placed..." message is a FAQ: http://www.cfd-online.com/Wiki/Ansys...f_an_OUTLET.22
First of all, note it is a warning, not an error. You may be accurate enough despite the warning. But to eliminate the problem (and it usually is a problem) you should move the outlet to somewhere no back flow exists. This usually means moving the outlet boundary further downstream.
Thread Tools
Trackbacks are On
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 15 April 20, 2016 11:56
[ICEM] further refinment - Radial turbine Far ANSYS Meshing & Geometry 14 March 19, 2014 09:12
[DesignModeler] Hollow surface to solid body ?? - radial turbine pengxudong ANSYS Meshing & Geometry 0 February 24, 2014 13:44
guidance for correcting results for a variable geomerty radial turbine. Priya NUMECA 0 March 17, 2013 17:35
radial turbine blade simulation with dynamic mesh 6dof(fluent) mamyjooooon FLUENT 0 April 7, 2011 14:28
