Home > Forums > CFX
Total pressure boundary condition at inlet:how to sustain inlet pressure in cfx
Old   March 10, 2014, 06:59
Default Total pressure boundary condition at inlet:how to sustain inlet pressure in cfx
faizan is on a distinguished road
Hi All,
I have selected Total pressure of 1.4MPa at Inlet in ANSYS CFX software. I am modeling a Nitrogen gas flow through convergent-divergent DeLaval Nozzle. I set a areaAve(Pressure) monitor at inlet in solver control monitors. After 3 4 iterations the inlet monitor shows drastic drop of pressure form 1.4e6 Pa to 2e5Pa. How can I imposed a constant total pressure boundary condition at Inlet? Please help...
faizan is offline   Reply With Quote
Old   March 10, 2014, 17:18
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
You imposed constant total pressure. You are monitoring pressure. The difference is the dynamic head. If your monitor on total pressure it should be your boundary value setting.
Old   March 10, 2014, 23:52
Thanks ghorrock for your response.
Can you suggest me about the expression of total pressure monitor?
Old   March 11, 2014, 07:29
areaAve(Total Pressure)@inlet
Look in the CFX reference manual for a full list of available variables and their names.
Old   March 15, 2014, 23:28
Thanks ghorrock,
I have solved the total pressure issue. But another problem occurred with total temperature. When I set the total temperature expression at inlet it is just showing a flat line at 0 value. The total temp at inlet is set to 550 deg C. Please see the attached picture and reply.
Thanks in advance.
Old   March 16, 2014, 05:37
Have you seen the y scale size? Maybe you should put the temperature curve on another plot with more appropriate scaling.....
Old   March 17, 2014, 21:53
Thanks ghorrocks- I have separated the plots and now it is better.
Can you suggest that how can I put the pressure monitors on different locations over the length of nozzle. At the moment I put the monitor on inlet and it is showing. I need to check the pressure on throat section which is at 81.2 mm linear distance from inlet. Also one pressure monitor at exit of nozzle which is at 151.2 mm distance form the inlet.
How can I set the pressure monitor at these distances ? please suggest.I am CONFUSED...
Old   March 17, 2014, 23:44
Try a monitor point set at a specific XYZ location.
Old   March 18, 2014, 05:06
This is the problem. I am unable to find from where and how can I set specific location at nozzle length.
I tried the option imprint but it is not showing and inactive in my model because my model geometry have frozen bodies.
Please suggest?
Old   March 18, 2014, 07:27
chiragsvnit's Avatar
Chirag Trivedi
chiragsvnit is on a distinguished road
Send a message via Skype™ to chiragsvnit
Have you created monitoring points using XYZ values at CFX Pre during job set-up along with monitoring variables? The option is available in Monitoring Tab CFX Pre.
chiragsvnit is offline   Reply With Quote
Old   March 18, 2014, 17:47
You do not set up monitor points in the meshing. You set it up in CFX-Pre.
Thread Tools
Trackbacks are On
convergenceof natural convection prob. in cfx cpkewat CFX 15 January 31, 2014 07:29
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Low Mixing time Problem Mavier CFX 5 April 29, 2013 00:00
Pressure Inlet Boundary Condition Prasad FLUENT 6 April 9, 2013 21:32
Question about pressure inlet boundary condition. Alina FLUENT 1 November 30, 2007 08:39
