April 4, 2014, 07:26 |
Mr CFD
Rep Power: 14 |
OK - this means the equation has converged very well.
ok - this means the equation has not converged as well as it should. ! - this means the equation has not converged, and the result should not be trusted. It's all in the CFX guides. |
April 4, 2014, 08:44 |
#3 | |
Rep Power: 18 |
* indicates that there was a numerical floating point exception and this resulted in the failure of the linear solvers. F indicates that the linear solvers did not reduce the residuals (that is, the solution was diverging), but the linear solvers may carry on if the divergence is not catastrophic. ok indicates that the residuals were reduced, but that the degree of reduction did not meet the specified criteria. OK indicates that the specified convergence criteria for the reduction of residuals was achieved. |
April 4, 2014, 08:50 |
Simon
Rep Power: 11 |
Thanks for information
Display Modes | |
A turbulent test case for rhoCentralFoam | immortality | OpenFOAM Running, Solving & CFD | 13 | April 20, 2014 07:32 |
IdeasUnvToFoam Bug amp Fix | benru | OpenFOAM Bugs | 42 | November 13, 2009 08:59 |
Solution technique/ Mesh type/ Cell limit/ Multi-zone regions in CFX | zandi | CFX | 5 | April 10, 2009 02:06 |
Water pump OpenFOAM 15 ANSYS CFX 110 comparation | waynezw0618 | OpenFOAM Running, Solving & CFD | 39 | March 5, 2009 13:57 |
how to make a CFX solution | NITIN DEWANGAN | CFX | 2 | August 8, 2008 09:06 |
