Observing a Recirculated Flow Proximal to a Constriction |
April 1, 2014, 00:17 |
Ashkan Javadzadegan
Rep Power: 16 |
Dear all,
I am modelling flow in an artery, which is initially (t = 0 s) unimpeded, then starts to narrow to form a constriction (t = 0.4 s) and finally returns to its initial non-constricted state (t=1 s). I use pressure waveform as inlet boundary condition and axial velocity waveform as outlet boundary condition (please see the attachment). I have observed a recirculated flow proximal to the constriction experimentally, however, the modelling results do not predict that recirculation! The problem might be because of boundary conditions!! Does anyone know what boundary condition could predict a recirculated flow proximal to the constriction? Regards, AshtonJ |
April 1, 2014, 18:20 |
Rep Power: 143 |
No images are attached.
Have you done all the normal accuracy checks? http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
April 1, 2014, 19:52 |
Ashkan Javadzadegan
Rep Power: 16 |
Dear ghorrocks,
Yes, I've done grid dependency and error analysis test. My question is whether observing a recirculation proximal to a stenosis is possible from CFD point of view? If yes, please let me know the physical condition under which it happens. Actually, I have not come across this before. Thanks |
April 1, 2014, 20:08 |
Rep Power: 143 |
Can you post an image of what you are seeing?
April 1, 2014, 20:28 |
Ashkan Javadzadegan
Rep Power: 16 |
Please the following image:
As seen, a recirculated flow region is observed in pre-stenosis region. |
April 1, 2014, 20:43 |
Rep Power: 143 |
Strange - the email notification included the link but the web forum has stripped it. I don't know what it happening there.
Anyway, I have seen the picture now. It looks unusual and you would need unusual circumstances to make that come about. It is possible that it is caused by inadequate convergence, but it could also be caused by your boundary conditions. You would have to do some post processing to work that out. |
April 1, 2014, 20:47 |
Ashkan Javadzadegan
Rep Power: 16 |
Actually, I've seen that pre-stenosis recirculation experimentally, I want to create the same thing by CFD ...
April 1, 2014, 20:49 |
Rep Power: 143 |
Sure, but if the recirculation occurs right next to your boundary condition I would be very suspicious of it. You want to make sure important flow stuff happens well away from your boundary conditions. So you might need to move your upstream boundary condition further upstream.
April 1, 2014, 20:58 |
#9 |
Ashkan Javadzadegan
Rep Power: 16 |
It does not happen next to the boundary, it is far from inlet. In my laboratory experiment, in a 600 mm Pipe, a recirculation was observed 150 mm far from inlet and 100 mm far from beginning of stenosis.
April 1, 2014, 22:09 |
#10 |
Rep Power: 143 |
If your boundary condition has the flow going in one direction then stops it and reverses the direction this can cause recirculations.
Different flow patterns in CFX and Fluent | avi@lpsc | CFX | 6 | April 17, 2012 01:22 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 08:33 |
mass flow inlet | Denis Tschumperle | FLUENT | 7 | August 9, 2000 02:19 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
computation about flow around a yawed cone | Tylor Xie | Main CFD Forum | 0 | June 9, 1999 07:33 |
