Error interpolating results onto the new mesh
Old   April 7, 2014, 14:48
Default Error interpolating results onto the new mesh
ali
alinik is on a distinguished road
Hey Guys,
I am simulating a remeshing problem more or less similar to the one in this example:
http://www.edr.no/index.php/blogg/an...cfx_re_meshing
I receive this error while running it.
| ****** PROBLEM REPORT ****** |
| Subsystem: Input and Output |
| Subroutine name: ErrAction |
| Severity level: Fatal Error |
| Error message number: 001100279 |
| Message: |
| REDHDR: locating dataset failed: what=G/NAMEMAP where=EVERY |
WARNING: CFXSTP, Regression check error.
| An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: |
| /g/software/ansys_inc/v150/CFX/bin/linux-amd64/double/solver-pcmp- |
| i.exe exited with return code 1. |
Any idea?
alinik is offline   Reply With Quote
Old   April 8, 2014, 19:24
ali
any one has had same problem? any idea?
Old   April 9, 2014, 06:54
CFX error messages are not very helpful, are they?
I think this is saying it had a problem reading some sort of file header. You are going to have to do some clever debugging to find this problem - run the tutorial, does it work? Then change one thing at a time to turn it into your simulation and see what breaks it. You might be able to work out more direct methods of debugging it but I cannot suggest much based on the little information you have posted.
Old   April 9, 2014, 09:04
ali
Glenn,
Thanks, Will do that. But really that is all that CFX is giving me about the error. I have no more information about what is really happening
Old   April 9, 2014, 20:06
That is why you have to start from a known working state and slowly move to the error condition. Then you can hopefully isolate what step is causing the error.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 11:14
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
How to import results of a case as initial data for other when mesh size is different Kartik FLUENT 0 March 27, 2012 07:56
[OpenFOAM] 'integrate variables' filter on a polyhedral mesh gives wrong results... jbf ParaView 0 September 4, 2009 04:08
