Comparing cases in CFD-post : Using scalar speed |
April 11, 2014, 06:11 |
Simon
I am new to CFD-Post, and am trying to use CFD-Post to compare two cases, in order to plot the differences in speed between them.
If I plot u-velocity or v-velocity and use the Compare Cases tool, this is straightforward. However, the flow is not parallel to either axis so these are not useful for this purpose. If I plot simply "velocity", then all differences appear as positive, regardless of whether the "Use absolute value of difference" checkbox is checked. I speculate that this is because internally, the program is calculating the differences in u- and v-velocities and then deriving the magnitude from that - which of course is always positive. How can I show the positive and negative differences in scalar speed between two cases? From some googling I get the feeling that I may be able to "do it myself" using CEL, but I'm not clear on how. Many thanks for any advice. |
April 11, 2014, 06:55 |
Lance
Rep Power: 22 |
I would do something like this
1) Create a CEL expression called velmag as sqrt(velocity u^2+velocity v^2+ velocity w^2) 2) assign expression velmag to a new variable called speed 3) perform case comparison. |
April 11, 2014, 11:12 |
#3 | |
Simon
I think what I had missed was the need to first great an expression and then assign it to a variable - I had been trying to do this in one step and getting confused. |
Plotting Radial Velocity and Tangential Velocity in CFD Post | ashtonJ | CFX | 5 | July 13, 2015 02:49 |
Plotting the Viscosity Contour in CFD Post | ashtonJ | FLUENT | 3 | June 2, 2015 12:06 |
FEA results in CFD Post | delaneyluke | CFX | 1 | October 25, 2013 06:16 |
Poly lines in CFD Post | ashtonJ | CFX | 0 | December 2, 2010 02:46 |
(CFX POST) Rotational Speed | ARJUN | CFX | 9 | July 13, 2006 20:38 |
