April 16, 2014, 02:59 |
subroutine error
Rep Power: 15 |
Hello all.
Please can anyone tell me what is this message and what can I do about it? Thank you in advance. Best regards |
April 16, 2014, 06:07 |
Rep Power: 143 |
I have no idea what that means.
So you need to debug this as you do for any inexplicable error message - simply your model until it runs. Then add the complex bits one at a time until you identify which bit is causing the error. Then at least you know where to look. |
April 16, 2014, 06:18 |
Rep Power: 15 |
Thank you ghorrocks for reply. I solved the problem by simple deleting all domains and interfaces and nemed them simply (1,2,...). And it works now.
So thanks again |
April 16, 2014, 23:47 |
#4 | |
Rep Power: 32 |
If you search in the documentation for convert_name_u2s, you will find the following
Hope the above helps, |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
