subroutine error
1 Attachment(s)
Hello all.
Please can anyone tell me what is this message and what can I do about it? Thank you in advance. Best regards |
I have no idea what that means.
So you need to debug this as you do for any inexplicable error message - simply your model until it runs. Then add the complex bits one at a time until you identify which bit is causing the error. Then at least you know where to look. |
Thank you ghorrocks for reply. I solved the problem by simple deleting all domains and interfaces and nemed them simply (1,2,...). And it works now.
So thanks again |
If you search in the documentation for convert_name_u2s, you will find the following
Hope the above helps, |
