Question abt the CFX tutorial regarding scaling of the rotor blade row! |
April 24, 2014, 05:46 |
Minoo
Rep Power: 12 |
I have a very basic question. In the axial turbine example in the CFX tutorial, the rotor has 113 blades and the stator has 60 blades. The blade row is scaled with the factor of 0.942 (using two blades and one vane). However the blade row is not actually scaled, since the total number of blades used, based on which the flow passage is created, are still 113 while I expected it to be approximated to 120! Could anyone be so kind to explain this to me?
question about the channel395 tutorial | huangxianbei | OpenFOAM Running, Solving & CFD | 6 | May 8, 2017 03:09 |
Question about CFX turbulence intensity | Anna Tian | CFX | 5 | May 7, 2015 18:13 |
Turbogrid | MAP7 | Main CFD Forum | 0 | April 14, 2014 15:38 |
CFX Momentum Inputs Question | gsmith | CFX | 2 | October 21, 2013 10:46 |
Question about meshing / solution scheme of CFX | Coriolius | CFX | 8 | August 1, 2004 18:39 |
