CHT Oil heat exchanger problem
Old   May 2, 2014, 10:13
Default CHT Oil heat exchanger problem
Jakub
kubawin is on a distinguished road
Hello there
In a first place, I must say that I'm quite new to CFD analysis, but I've read and done appropriate tutorials about CHT analysis.
My model is steel coil in which flow thermal oil. These heat exchanger is located in exterior similar to this shown in picture below.
Input/Output data is in .txt file in attachment.
Problem is that solver won't run, showing the comment:
Return value C0000005 >FFFF in parse_rv, treating as not-run.
I've tried doing it from the beginning, correcting and simplifying model but the error stays the same.
I suspect these two highlighted 2d regions fayed to inlet and outlet 2d regions, but I hadn't that error in exact situation in different model.
I would very appreciate any help.
output.txt
kubawin is offline   Reply With Quote
Old   May 2, 2014, 13:25
Jakub
I've changed solid domain between oil and fumes into thin surface interface model. Apparently, there is an solver error too:
| Convergence History |
| Timescale Information |
| Equation | Type | Timescale |
| U-Mom-Fumes | Auto Timescale | 2.98064E-02 |
| V-Mom-Fumes | Auto Timescale | 2.98064E-02 |
| W-Mom-Fumes | Auto Timescale | 2.98064E-02 |
| P-Mass-Fumes | Auto Timescale | 2.98064E-02 |
| U-Mom-Oil | Auto Timescale | 2.98064E-02 |
| V-Mom-Oil | Auto Timescale | 2.98064E-02 |
| W-Mom-Oil | Auto Timescale | 2.98064E-02 |
| P-Mass-Oil | Auto Timescale | 2.98064E-02 |
| H-Energy-Fumes | Auto Timescale | 2.98064E-02 |
| H-Energy-Oil | Auto Timescale | 2.98064E-02 |
| K-TurbKE-Fumes | Auto Timescale | 2.98064E-02 |
| E-Diss.K-Fumes | Auto Timescale | 2.98064E-02 |
| K-TurbKE-Oil | Auto Timescale | 2.98064E-02 |
| E-Diss.K-Oil | Auto Timescale | 2.98064E-02 |
OUTER LOOP ITERATION = 35 ( 1) CPU SECONDS = 4.353E+04 (1.220E+02)
| Equation | Rate | RMS Res | Max Res | Linear Solution |
| U-Mom-Fumes | 3.81 | 1.3E-03 | 3.2E-01 | 2.5E-02 OK|
| V-Mom-Fumes | 2.16 | 1.8E-03 | 3.2E-01 | 2.3E-02 OK|
| W-Mom-Fumes | 1.85 | 1.0E-03 | 6.5E-02 | 4.2E-02 OK|
| P-Mass-Fumes |47.19 | 1.1E-02 | 1.9E+00 | 8.8 4.2E-02 OK|
| U-Mom-Oil | 0.00 | 3.0E-04 | 4.1E-02 | 8.5E-02 OK|
| V-Mom-Oil | 0.00 | 3.3E-04 | 4.2E-02 | 6.8E-02 OK|
| W-Mom-Oil | 0.00 | 1.4E-03 | 1.5E-01 | 9.7E-02 OK|
| P-Mass-Oil | 0.00 | 3.3E-03 | 3.7E-01 | 8.7 4.6E-02 OK|
Error in subroutine FNDVAR :
Error finding variable TEMP
GETVAR originally called by subroutine UPDATE_CSVAR
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine GV_ERROR
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. No results file |
| has been created. |
End of solution stage.
Anyone could show me the way to overcome this?
Thanks
Old   May 2, 2014, 19:03
Jakub
Problem solved
EDIT:
Apparently, it's not. I mean, sometimes it appears sometimes not. Could it have something in common with static/total temperature? On inlet boundaries I use cartesian velocities.
2D heat exchanger problem Kwiaci FLUENT 0 June 7, 2012 07:12
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
facing problem in heat transfer coefficient dhiraj CFX 1 May 7, 2007 09:08
heat exchanger problem pratap FLUENT 0 June 4, 2005 06:33
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
