April 30, 2014, 06:43 |
CFX Highlight Domains and Boundaries
Daniel Frederik
Rep Power: 12 |
Hi everybody,
In CFX normaly when you click on a boundary or a domain in the outline the corresponding element should Highlight in the 3D view. I don't know what happened but it doesn't in my case. How can I modify that? |
November 27, 2020, 04:06 |
anandh
Hi Daniel,
I am facing the same issue. Can you share your views on how you resolved it. |
November 28, 2020, 14:19 |
Kira
Rep Power: 8 |
Hello Daniel,
Are you talking about CFX-Pre or -Post? Also sharing a screen capture of your current load out might help us diagnose the problem. In -Pre, make sure the boxes beside your domains are checked off. I was able to highlight mine by just clicking on the name in the outline. |
November 29, 2020, 10:21 |
#4 | |
Gert-Jan
Rep Power: 27 |
Maybe you should go to the tool bar and select: Edit -> Options There you see a lot of settings. At the bottom you see CFX-Defaults and Workbench-Defaults. I expect your problem is resolved if you select CFX-Default. |
November 29, 2020, 11:31 |
anandh
Hi Gert-Jan,
Thanks for the suggestion. My problem is solved by uncheck and check the highlighting feature in the viewer's toolbar. |
[ANSYS Meshing] Displaying solid domains in CFD Post without meshing them. | hda | ANSYS Meshing & Geometry | 5 | October 24, 2016 09:26 |
ISSUES: Rotating VS Non-Rotaing Domains | gigiboumba | CFX | 3 | April 26, 2014 07:22 |
Two Domains simulation | lucasphp | CFX | 2 | January 21, 2013 10:37 |
Fluid Regions donot communicate via "Attach" Boundaries | sdwijeya | STAR-CD | 0 | August 28, 2009 13:26 |
Wind turbine domains and boundaries | siardica | CFX | 3 | July 20, 2009 22:34 |
