CFX Remeshing failed ERROR
Old   April 30, 2014, 06:49
Question CFX Remeshing failed ERROR
Ashkan Javadzadegan
ashtonJ is on a distinguished road
Dear all,
I am trying to model fluid flow in a tube using CFX-Workbench Remeshing.
I got the following error at the begging of remeshing process;
An error has occurred in cfx5solve:
C:\Program does not exist
MeshMod: Call to user defined mesh modifications failed. could not be started: Executable C:\Program not found.
Remeshing: Failed to modify mesh for remesh object
Remeshing failed.
Here is my remeshing settings:
Interruption Control: minVal(Orthogonality Angle Minimum )@Artery<10 [deg]
External Command: C:\Program Files\ANSYS Inc\v145\Framework\bin\Win64\runwb2.bat" -B -R "E:\Model\Bridge Test With Remeshing\WB_Remesh.wbjn"
Replacement File: E:\Model\Bridge Test With Remeshing\Bridge T Remeshing_files\dp0\global\MECH\SYS.mshdb
Could anybody help me to find out why I got the above error at the beginning of the remeshing process.
Thanks
AshtonJ
ashtonJ is offline   Reply With Quote
Old   April 30, 2014, 07:40
Lance
Lance is on a distinguished road
This is most certainly due to the space between Program and Files in the path to the executable.
Lance is offline   Reply With Quote
Old   April 30, 2014, 07:56
Ashkan Javadzadegan
Thanks Lance.
I ran it in C and E drives, however I got the same error!
In this case, where you suggest to run the simulation?
Old   April 30, 2014, 08:08
Lance
Try the A, B or D drive! (that was a joke...)
The path to some of your files contain a space, e.g. 'Program Files' and 'Bridge Test With Remeshing'. Add " before and after the paths and see if that solves your problem.
Old   April 30, 2014, 22:58
Ashkan Javadzadegan
Dear Lance,
As suggested, I have tried the following path format, but I am still getting the same error at the beginning of the remeshing.
1.
"C:\"Program Files"\"ANSYS Inc"\v145\Framework\bin\Win64\runwb2.bat"-B-R"E:\Model\"Bridge Test With Remeshing"\WB_Remesh.wbjn"
2.
"\"C:\"Program Files"\"ANSYS Inc"\v145\Framework\bin\Win64\runwb2.bat\""-B-R"E:\Model\"Bridge Test With Remeshing"\WB_Remesh.wbjn"
3.
@"""C:\"Program Files"\"ANSYS Inc"\v145\Framework\bin\Win64\runwb2.bat"""-B-R"E:\Model\"Bridge Test With Remeshing"\WB_Remesh.wbjn"
Do you have any idea what the problem is?
Thanks
Old   May 1, 2014, 00:12
All of your attempts have used the wrong format. The easiest way of getting the correct format is to fire up a command window and use the tab file completion gizmo to get the file names right. When I do that I get the command line to be (with a guess for your personal files):
"c:\Program Files\ANSYS Inc\v145\Framework\bin\Win64\runwb2.bat" -b -R "E:\Model\Bridge Test With Remeshing\WB_Remesh.wbjn"
Old   September 16, 2016, 15:41
Default I´ve got the same error
Luiz Zubeldia
Zubeldia is on a distinguished road
Dears,
I just started to work with remesh so I looked for a ready configuration and I found this one:
http://cae-club.ru/files/remesh61214
I was working with this on Ansys V16.2 and I was sucesfull in remesh it when I changed the total time from 1[s] to 3[s] and changed the directory name of External Command. It stoped the cfx solver and executed the meshing and returned to cfx without problems
But after the update to V17.1 the same simulation, with the directory name corrected from v162 to v171 fails .
Any idea about what could be the problem?
Zubeldia is offline   Reply With Quote
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
