Home > Forums > CFX
Diffrence between areaAve and ave
Like Tree2Likes
  • 1 Post By ghorrocks
Old   May 6, 2014, 11:17
Default Diffrence between areaAve and ave
Julez
Cucko is on a distinguished road
Hello all,
I am a greenhorn at cfx so sorry for my stupid question. My Problem is that my geometrie is a rectangular microchannel with same cross section at Inlet and Outlet. I used the function AreaAve at Inlet and get 0.00318 m/s. At the Outlet i get 0.00331 m/s (after Grid study). My opinion is that this value is false, because of continuity equation it have to be the same value (density is the same) v1*A1=v2*A2 (A1=A2). If i use the ave Velocity function i get nearly the same value. So is the areaAve function the wrong for calculating velocitys at areas?
Sorry for my bad english and thanks for any help
Greetings cucko
Cucko is offline   Reply With Quote
Old   May 6, 2014, 19:56
ghorrocks has a spectacular aura aboutghorrocks has a spectacular aura aboutghorrocks has a spectacular aura about
Is your simulation converged? It could be inadequately converged.
If your flow is incompressible with the same area for inlet and outlet then the areaAve velocity should be the same. What answer do you get when you use the massflow() function?
Cucko likes this.
Old   May 7, 2014, 04:00
Julez
Hi Glenn,
Thanks for ur quick answer.It was a simulation with water at 23C (isothermal); so incompressible fluid. Its a laminar simulation (Reynoldsnumber at Inlet should be 2).
It is really freaky but i get with the function =massflow()@Inlet this value 1.000e-05 [kg s^-1] for the Outlet =massflow()@Outlet = -1.000e-05 [kg s^-1].
So this should be true. The Convergence was still ok and the Imbalance was nearly zero. I thought it could be a fault/artefact from the mesh. But my mesh is still ok i think. Min Angle >32 Determinant2x2x2 >0,7 Aspect ratio <10.
So i m really confused .
Old   May 7, 2014, 07:22
Can you post an image of what you are modelling?
Old   May 7, 2014, 07:27
Julez
Hi Glenn,
Sure. This is an Pic of a XZ Plane in the middle of the channel.
Old   May 7, 2014, 09:07
I am not certain of this but I suspect the areaAve() function averages the nodal values over the control volume face, but massflow() uses the integration points to integrate the flow. This means massflow() is more accurate.
Cucko likes this.
Thread Tools
Trackbacks are On
Distinguish between MassFlow Ave and AreaAve Badrinath CFX 1 February 15, 2006 00:33
