Question about mesh copy for periodic geometry at CFX |
July 25, 2012, 04:58 |
lnk
Rep Power: 15 |
Hi everyone,
Thanks for your time to look at my question. I have periodic geometry. I'd like to generate mesh by ICEM only to one and then copy the mesh to the others by CFX. May I ask how to copy mesh? Best regards and many thanks again, lnk |
July 25, 2012, 18:26 |
Rep Power: 143 |
In CFX-Pre use the mesh transform options. In that you have options to copy the mesh or to move it. In your case copy it to create copies, and you also have tolerances to allow it to merge it to adjacent meshes.
July 26, 2012, 08:48 |
#3 | |
lnk
Rep Power: 15 |
Thanks for your answer. What about I do it at ICEM? Is there any difference? By the way, I didn't find that button at CFX-Pre. Could you tell me where is it? Best, lnk Last edited by lnk; July 26, 2012 at 09:20. |
July 26, 2012, 19:20 |
Rep Power: 143 |
Yes, you can do it in ICEM as well.
May 9, 2014, 10:43 |
Daniel Frederik
Rep Power: 11 |
I am transforming my mesh translational. I dont know why but it doesnt accept it as one entire volume when i copy them. Gluing adjacent meshes didnt work. I have also set peridiocities in ICM (don't know if that was necessary). But what can I do that i have not isolated volumes?
May 10, 2014, 08:16 |
Rep Power: 143 |
When you translate a mesh in CFX-Pre you can set it to glue the meshes together - but this requires the mesh on the matching faces to be EXACTLY the same. Even a small difference in a single node will cause it to fail.
Alternately you can use a multi body part in ANSYS meshing or single surfaces separating multiple body points in ICEM. |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ANSYS Meshing] Geometry Mesh Deformation question | LukeFullard | ANSYS Meshing & Geometry | 2 | July 22, 2012 16:46 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
