Writing Equation
Dear Friends,
I have to calculate an expression which includes a term as written below: |Ui-Vi| Where Ui and Vi are velocity vectors of gas and particles. Could you plz suggest me how to write these vectors in expression. In results I found velocities in x, y and z direction available in drop down list. Thanks |
Subtract each component and save them in an Expression
myVelU = Fluid.Velocity u - Gas.Velocity u myVelV =... myVelW=... and create a User Variable Vector from these 3 components. Or you can skip the variable and apply the norm directly to you expression like myVelNorm = sqrt((myVelU)^2 +....) |
Dear Matthias, Thank you for the reply, I will follow this: "myVelNorm = sqrt((myVelU)^2 +....)" At the same time could you plz suggest me on how to create a User Variable Vector? Regards |
In CFD-Post--> click on Create Variable (little alpha) and select vector instead of scalar.
Thank you again Matthias, its great. |
