CFX-Pre Batch
Like Tree3Likes
  • 1 Post By Daniel Frederik
  • 1 Post By mvoss
  • 1 Post By PeMo
Old   June 18, 2014, 02:14
Default CFX-Pre Batch
Daniel Frederik
Daniel Frederik is on a distinguished road
Hi everybody,
I have made the setup of a Gasturbine simulation. Now i'd like to simulate that at different massflows and révolutions. Is there a way i can create the different def files by batch mode? It would just be necessary to change massflow and révolutions.
Any ideas?
Thanks
ferferimori likes this.
Daniel Frederik is offline   Reply With Quote
Old   June 18, 2014, 03:09
Matthias Voß
mvoss is on a distinguished road
Check for the command line arguments (e.g. -ccl) of the cfx5solve. You can create "new" def files from an existing one and run them OR run the same def-file with the -ccl and input snippets changing the app. places each time.
ssrmin@naver.com likes this.
mvoss is offline   Reply With Quote
Old   June 18, 2014, 03:27
Peter
PeMo is on a distinguished road
You can add a ccl to modify the original def-file during start up. Just add a -ccl name.ccl to your start-up command. Open in Pre a Domain with the Command editor to see how the ccl should look like.
For instance to change the massflow it is sth like (untested!):
FLOW: Flow Analysis 1
DOMAIN: SVWG
&replace BOUNDARY: Inflow
Boundary Type = INLET
Location = inlet
MASS AND MOMENTUM:
Mass Flow Rate = newMassFlow
Option = Bulk Mass Flow Rate
END
END
END
END
Edit: too slow....
PeMo is offline   Reply With Quote
Setting Pressure Boundary Conditions in ANSYS CFX Pre saisanthoshm88 CFX 21 February 22, 2017 16:50
Using Condor for batch queing with CFX ellevset CFX 3 June 16, 2016 12:09
Batch in CFX 12 in Windows XP Jade M CFX 18 February 6, 2013 09:29
Pre in batch mode Kuts CFX 7 August 17, 2007 05:10
CFX 5.7.1 PRE and solver won't start daniel CFX 1 January 20, 2006 10:09
