Home > Forums > CFX
How can I deal with deformable body in CFX?
Old   July 3, 2014, 10:33
Default How can I deal with deformable body in CFX?
Sangwoo Kim
swtbkim is on a distinguished road
Hi. I'm a new user of CFX.
I'm trying to simulate wheels rotating on the road, and it is difficult to handle a deformation of rubber tire.
I think it can be solved by assuming that the tire rubber is deformed by specific angle or something and using dynamic mesh in FLUENT.
What about in CFX?
Actually, I just have a conceptual idea of using dynamic mesh in FLUENT.
I don't know how to do, and even whether it is possible or not.
Is there a material that would be helpful in this case?
Thank you.
swtbkim is offline   Reply With Quote
Old   July 3, 2014, 18:41
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Why do you need to use deforming mesh? Can't you apply the rotation of the tyre as a tangential wall motion on a fixed mesh?
Old   July 3, 2014, 20:44
Sangwoo Kim
Thank you for your reply, ghorrocks.
Because the part of the tire in contact with the ground is deformed flat.
Tire will be treated as keeping rotating, and deformed part will be changed continuously.
So I think a fixed mesh is not proper.
Old   July 3, 2014, 21:36
If you look at the motion in the frame of reference of the vehicle then the surface of the tyre has no normal motion, only tangential. Therefore moving mesh is not required, just a tangential velocity on a stationary mesh.
The deforming bit will just mean the tangential velocity is not a pure rotational motion. But I bet assuming it is a pure rotation will be so close as to be good enough.
Old   July 3, 2014, 21:59
Sangwoo Kim
You mean it is enough to simulate just a circle tangential with a line?
Then, if I want more realistic analysis, so deformation of tire should be considered,
is stationary mesh still enough?
Old   July 3, 2014, 22:46
I do not understand your comment "You mean it is enough to simulate just a circle tangential with a line?"
Have a think about how a tyre rolls along, and look at it from the frame of reference of the vehicle. Then you will see what I am talking about.
Old   July 4, 2014, 00:26
Sangwoo Kim
What I asked was whether or not it's fine to ignore the deformation of tire rubber.
And I wanted to include deformation whether it is negligible or not.
I will try to do, anyway.
Thanks very much for your advice
Old   July 7, 2014, 10:50
stumpy is on a distinguished road
I think you're missing Glenn's point. Generate a mesh that includes the flat-spot on the tire, then apply a wall velocity to the tire surface. This does not move/deform the mesh.
stumpy is offline   Reply With Quote
Old   July 9, 2014, 02:44
Martin_Sz's Avatar
Marcin
Martin_Sz is on a distinguished road
Dont use CFX for this analysis .
Use LS-Dyna for contacts problems.
On this module you can define elasto/visco plastic material for rubber, rotational speed, vertical force and contact beetween surface and wheel.
Martin_Sz is offline   Reply With Quote
Old   July 9, 2014, 02:48
I am assuming Sangwoo is looking at the air flows over a tyre. LS-DYNA is not so good for this and CFX is a good choice for this type of analysis. But yes, if the shaped of the deformation of the tyre is the important thing then something like LS-DYNA should be considered.
Old   July 9, 2014, 03:03
Sangwoo Kim
Oh got it. You are right.
Problem was that I didn't understand how moving wall function acts. It was silly question.
Thank you very much.
Old   July 9, 2014, 03:06
Sangwoo Kim
Thanks for your reply. But I'm interested in airflow in the wake of the wheel as Glenn says.
My words might be confusing.
Old   July 9, 2014, 03:07
Sangwoo Kim
I finally got it what was wrong.
Really thank you for considerate replies =)
Old   May 21, 2015, 11:56
Default please share your findings
  #14
PG
pg37 is on a distinguished road
I think I'm trying to model a similar problem.
Could you share what you figured out about flow around a tire in contact with gorund surface?
pg37 is offline   Reply With Quote
Thread Tools
Trackbacks are On
6dof model - floating body flinde FLUENT 5 May 4, 2016 12:19
[Need some advise] Am I doing right?? Simulating a rotational mixer setasena STAR-CCM+ 4 March 10, 2013 11:32
How find Drag coefficient of a body with ANSYS CFX Jhonathan CFX 2 October 2, 2008 18:07
Good Switch deal from CFX to Fluent User who switches CFX 6 May 17, 2006 13:00
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
