July 7, 2014, 06:30 |
help me for bucket spillway?
Hydreaulic structures
Rep Power: 14 |
hi every one
I've modeled the bucket spillway, I have two gols in the flow simulation: 1- I would like to calculate the distance jet launching, i know should use the formula projectiles, but how do you define in cfx??? 2- i have decide optimize radius of bucket,So we have the most current launch. please help me thanks a lot |
July 7, 2014, 15:41 |
Mr CFD
Rep Power: 14 |
Surely the first step is to start with hand written calculations. Then try a few different radii and bucket distances, run simulations on those and compare the results?
July 8, 2014, 03:47 |
Rep Power: 14 |
hi dear RicochetJ
That means you, i considered different radius of bucket and run my model, then with hand calculations compute jet launching??? Do not be using the software will automatically calculate the jet launch? Software does not have the ability to optimize?? thanks a lot |
July 8, 2014, 05:02 |
Mr CFD
Rep Power: 14 |
You could use parameterisation and goal optimisation in Workbench. I don't have any experience using goal optimisation so you need to read the literature.
July 8, 2014, 06:16 |
Rep Power: 143 |
Mr CFD's point is that you should spend 10 minutes doing some hand calculations to estimate what would be a good design and do simulations near that point - as each simulation is likely to take a day each, and probably a week to develop the method (if you know what you are doing).
July 8, 2014, 10:05 |
Rep Power: 14 |
dear ghorrocks
I want to radius of bucket with goal achieving maximum jet launching To optimize. I have two questions : 1- Is to optimize the radius of the bucket that I said goal in the above, calculations must be written hand and software optimization feature is not. 2- How to obtain distance jets launch? i know trajectory law is written by formula Which is given below but i how define this in cfx and use it? please help me thanks a lot |
July 8, 2014, 18:59 |
Rep Power: 143 |
I think you have missed the point again.
Simple hand calculations will give an approximate answer, but will only take a few minutes. You can do a simple optimisation on the hand calculations quickly. Simulations will be much slower but more accurate. You can make your hand calculation result more accurate with hand calculations. CFX works out the flow of the fluid using the Navier Stokes equations. To get it to launch a jet you have to configure it so a jet will form. |
Spillway simulation with interfoam, water disappearing through atmosphere | Wokl | OpenFOAM Running, Solving & CFD | 5 | July 12, 2016 09:42 |
Flow over stepped spillway | ftiago | OpenFOAM Pre-Processing | 1 | March 15, 2016 10:35 |
Materials / Tutorials for simulating flow over spillway | basud0817 | FLOW-3D | 4 | August 25, 2015 04:39 |
Calculating flow rate through a section of a spillway | Indus | FLOW-3D | 1 | November 5, 2012 18:54 |
Flow Over a Spillway | Nicopep | OpenFOAM | 1 | October 21, 2009 04:48 |
