July 11, 2014, 10:49 |
Overflow error
Ali ebadi
Rep Power: 11 |
آHello every one !
I am trying to model a two phase channel including water and air. I specify the velocity of water and air as the inlet boundary condition and average static pressure equal to zero for the outlet. The analysis type is transient. 100 kpa pressure and slight velocity are considered as initial condition. But every time that I run this code, program stops by overflow error. Who can help me ? |
July 13, 2014, 07:32 |
Rep Power: 143 |
Have you read the FAQ? http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
Are you sure your exit boundary is correct? Check the flow over a bump tutorial for how they do it. |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
