July 16, 2014, 16:09 |
Initial Condition Dependence of Residuals
I have seen in many codes documentation that the orders of magnitude of residual drop depends on how close the initial condition is to the final answer. A 5 order of magnitude drop may not even be possible if the initial guess is practically at the solution somehow.
However, CFX documentation says that due to their residual normalization scheme the residual drop is initial guess independent. That seems to indicate that no matter how good your initial guess is you should expect the same order of magnitude drop. Is this true/possible? Is this due to normalization based on the initial guess values somehow so that even if u-momentum only needs to change by 0.00001 kg*m/s because of a good initial guess it will still show it has dropped by 5+ orders of magnitude when finally converged (quickly converged I imagine being that close to the final answer). |
July 16, 2014, 17:10 |
Rep Power: 32 |
Residuals drop does not say anything about convergence besides that the iterations are going in the right direction, i.e. it is not diverging.
For example, if you start from the exact solution, the residual drop would be 0 (or undefined) since the residual is already 0. |
July 16, 2014, 18:01 |
Yes, I understand the definition and function of residuals academically as well as professionally. Documentation on other codes I have worked with (Numeca, Star-CCM+) make it clear that the residuals are initial guess sensitive. This only makes sense. How can an answer change by much if it is already incredibly close to the starting point?
However, CFX documentation states that the "residuals are initial guess independent". That would lead me to believe somehow, via some normalization, that no matter how close your initial is to the answer it will expect a big residual drop. Perhaps through division of the values by the initial, resulting in an artificially big number? I don't know, they don't detail all of their normalization methods, simply have that odd statement. I am curious to know because many solutions drop to deep residual levels (below 1e-6 RMS) while some others, which have acceptable monitor point convergence only drop to 1e-4 RMS. I know the monitor points, and often imbalances are more important, however, it is something that confuses me about residuals in CFX. |
July 17, 2014, 16:52 |
#4 | |
Rep Power: 32 |
The residual normalization procedure is explained in the ANSYS CFX documentation
Chapter 11: Discretization and Solution Theory | 11.2. Solution Strategy - The Coupled Solver Quote:
Hope the above helps, |
July 17, 2014, 20:17 |
That is the section I found as well. What I meant by not being fully explained is that while you learn the basic normalization procedure (which makes sense) you do not learn what the cell coefficient happens to be, for example.
But more importantly is the line "The normalized residuals are independent of the initial guess." I may be missing something, I admit, but the other codes I have worked with said normalization was dependent on initial guess, meaning if the initial guess is good the residuals may not change much, so the best way to judge convergence is via monitor points of critical characteristics. Here appears to say the opposite, and via some proprietary item in the normalization variables the residuals should drop to some absolute point to be considered converged. I.e. 1e-5 or so. |
July 18, 2014, 06:10 |
Rep Power: 143 |
Yes, the exact details of the residuals calculation are propriety and are not disclosed (unfortunately). A better way of looking at the residuals is that for most steady state simulations residuals = 1e-4 means approximate convergence, 1e-5 means convergence good enough for most design purposes and 1e-6 means very tight convergence. This is what it means initial conditions independence (and independence from just about everything else too, actually).
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Extremely slow simulation with interDyMFoam | jrrygg | OpenFOAM Running, Solving & CFD | 9 | April 23, 2013 10:14 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
