July 21, 2014, 05:03 |
RMS Fluctuation
Cafard
Rep Power: 11 |
Hi all,
when I caculate my turbine model I found that when the RMS Accumulated Time Step bigger then 400(sometimes 500),fluctuation will happen progressively. I tried to solve this question,then I found some setting may improve this phenomenon: 1. increase mesh quality I used turbogrid to mesh my turbine blade,but the Max.volume ratio is 7.7, (in turbomachine the value seems to be acceptable ?? ) and I thought the mesh size is small enought. 2. use upwind scheme 3. use mass outlet boundary I have done all these methods,but the flictuation don't reduce. May someone give me some recommends,thx a lot. |
July 21, 2014, 05:58 |
Rep Power: 143 |
This FAQ gives some tips: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
July 21, 2014, 23:01 |
Cafard
Rep Power: 11 |
I have read the FAQ,but I don't find something about residual fluctation??
July 21, 2014, 23:05 |
Rep Power: 143 |
Try a larger physical time step. You want a physical time step large than the oscillation period.
RMS fluctuation | saeedabedi | CFX | 1 | April 8, 2013 18:22 |
how to calculate rms velocity fluctuation after runtime | nati | OpenFOAM Post-Processing | 6 | February 7, 2013 08:42 |
Need Help Understanding RMS residual calculation | TWaung | CFX | 1 | September 22, 2009 18:21 |
RMS Res. is the smaller the best? | Anderson T F | CFX | 10 | September 12, 2007 05:59 |
Urgent help: RMS problem!!! | Anh | CFX | 4 | September 8, 2007 13:47 |
