July 29, 2014, 19:11 |
solar modeling
majid
Rep Power: 11 |
hi.i want to model a solar air heater.im in the cfx setup.but i have a problem with modeling solar radiation. i make a surface and create a radiation for it.totally i make 3 solid :fluid,plate,radiation plate.in set up i make a plate with thermal radiation monte carlo. my plate Temperature is vary by solar radiation.but in setup of cfx for boundary details,cfx said that you must set a fixed temperature and plate only receive radiation.what should i do?
Attachment 32707 Attachment 32708 Attachment 32709 |
July 30, 2014, 06:15 |
Rep Power: 143 |
Can you post an image of what you are trying to model and your CCL file or output file.
July 30, 2014, 09:05 |
majid
Rep Power: 11 |
thanks for answering.but the size of file is big what part i attach it.but see this images this is my file images .
setup image the outline image the problem |
July 30, 2014, 18:35 |
Rep Power: 143 |
What is the object floating in space? Radiation needs a domain to propagate through.
July 31, 2014, 05:38 |
majid
Rep Power: 11 |
now what should i do?i should make a room with air for radiation?or make domain interface for solid?
July 31, 2014, 06:57 |
Rep Power: 143 |
Have a look at the tutorials for how to set up radiation models. The combustion in a can combustor is one to look at.
Modeling the flow of solar radiation as the heat flux from the surface. | Gebbels | FLUENT | 0 | March 25, 2012 14:39 |
Modeling Solar parabolic Concentrating Cells | amit.at.msu@gmail.com | FLUENT | 0 | November 18, 2011 11:02 |
S2S Radiation Solar Modeling Help | yus310 | ANSYS | 0 | September 20, 2011 14:10 |
A problem with solar still modeling | Amir Khodabandeh | FLUENT | 2 | April 3, 2011 21:55 |
Solar radiation modeling in Star CCM+ V2 | Vmax | Siemens | 3 | February 27, 2007 05:33 |
