July 30, 2014, 08:18 |
[CFX-Post] Unit Conversion in Expression
#1 | |||
Marcel Jay
Rep Power: 11 |
Hello CFD Online Community,
I have an issue with changing the unit of an expression in CFD Post. Quote:
Would be glad if somebody ever solved that issue. Marcel |
July 30, 2014, 08:49 |
Erik
Rep Power: 23 |
Why not just change your unit system to custom in the options? Then change length and area to the units you want.
July 30, 2014, 09:05 |
Marcel Jay
Rep Power: 11 |
Thanks for the advice, but it won't work for Custom.
If I set Newton Millimeter as the system, it would display them in mm, but not for custom. What do i do wrong? |
July 31, 2014, 11:28 |
Rep Power: 14 |
Try to change the "Solution Units" under "Solver" in CFX-Pre and run CFX-solve again
August 4, 2014, 11:17 |
Edmund Singer P.E.
Rep Power: 20 |
Keep it unitless. What are you using this for? Just output to something else? If so just call the expression something like this so you know what it is:
area Auslass mm = area()@Auslass * (1000^2) *1[m^-2] |
writing execFlowFunctionObjects | immortality | OpenFOAM Post-Processing | 30 | September 15, 2013 06:16 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 18:44 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
Lift, Drag Vs time chart,calculations | Jamesd69climber | CFX | 8 | February 17, 2005 17:23 |
Unit of Expression | Fing | CFX | 2 | May 27, 2004 10:17 |
