September 25, 2014, 00:01 |
Modelling the movement of an artery
Ashkan Javadzadegan
Dear all,
I am trying to model the movement of an artery. I have the geometry file of the artery every 0.1[s], therefore in 1[s], I have 11 geometry files. Geometry 1 @ t=0 Geometry 2 @ t=0.1 . . . Geometry 11 @ t=1 I was just wondering how it is possible to model the movement of the artery such that geometry of artery changes from Geometry 1 to Geometry 11 in one cycle. Thank you. AshtonJ |
September 25, 2014, 06:19 |
Rep Power: 143 |
Do you want it to interpolate a smooth motion between the files you have? You will probably need this to get a smooth motion.
As long as your motion is not too massive then you can mesh them all with a mesh which is topologically the same and just move the nodes to the new geometry. Then you can do a mesh motion simulation which uses the series of mesh files. You will need user fortran to do this. There used to be a CFX example which did this but it has been removed in recent versions. If you asked ANSYS support they hopefully will still have access to the tutorial example. |
September 25, 2014, 22:49 |
Ashkan Javadzadegan
Thanks very much Glenn.
I contacted ANSYS support regarding that tutorial, but unfortunately they were not aware of that. Would you remember the name of the tutorial? |
September 26, 2014, 05:01 |
Rep Power: 143 |
It was the ball valve example from when moving mesh was new. So it was probably from about 8 years ago (!)
September 26, 2014, 21:23 |
Ashkan Javadzadegan
Thanks Glenn. In ball valve case, the topology does not change – i.e. the ball shape is not changing. However, in my case, the geometry of artery is changing. Do you think it is feasible to model that??
September 30, 2014, 05:18 |
Felix
Dear AshtonJ
Every kind of motion that you can define with a function in cartesian coordinate system or cylindrical coordinate system can be done with CEL in CFX. For example, you can define expansion of a lateral wall of a cylinder. This is possible if you have not large deformations otherwise you'll have bad mesh. I read that you have 11 geometries, you can load mesh of this geometries during the simulation ( interpolation of simulation in the new mesh is trilinear ). Pay attention that you can not do brute change of the geometry. bye Fely |
Modelling an artery | izzy13 | FLUENT | 1 | September 14, 2017 09:36 |
modelling wind movement | charltonjames | STAR-CCM+ | 8 | May 10, 2010 02:52 |
Modelling the movement of a liquid surface | C. Lucero | FLUENT | 4 | March 11, 2008 13:56 |
Modelling Movement of Trawler Nets in water | Chibisi | FLUENT | 0 | March 29, 2006 09:46 |
