September 26, 2014, 03:11 |
Vorticity, swirl etc.
Jiri
Rep Power: 13 |
I would like to monitor a variable that would give me an answer to how much fluid rotates in a pipe. Lets say the pipe is in the X direction and positive direction of flow is in X+. And the fluid little bit rotates around X axis. I created cross-section perpendicular to the X direction, and I want to monitor some variable corresponding with the fluid rotation. Neither on web nor in help I cant find any reasonable explanation of velocity.swirling normal, velocity.swirling normal X, velocity.swirling strength, velocity.swirling vector etc. I only found out what velocity.curl is. However I am still not quite sure about it, as in a pipe where I have nearly no rotation, velocity.curl gives much higher values than velocity.curl X,Y,Z. Thank in advance! |
November 30, 2022, 00:35 |
Wenjie Huang
Hi there. Have you solved your problem? I also want to know the answer.
November 30, 2022, 03:16 |
Gert-Jan
Rep Power: 27 |
What about areaAve(sqrt(Velocity v^2 + Velocity w^2)/max(abs(Velocity u),0.01[m/s]))@outlet
Of just monitor the v and w components, As an indication......... |
November 30, 2022, 08:02 |
Rep Power: 32 |
https://guilindner.github.io/VortexF...istic_equation
Though intended for something else, the summary and the references are a great starting point.
Quantifying the swirl in CFX, Swirl Number/Swirl Angle | tauqirnawaz | CFX | 23 | July 24, 2016 22:28 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
Quantifying Swirl | Ianto | Main CFD Forum | 0 | April 27, 2009 10:54 |
vortex, vorticity, swirl, helicity | lhb | Main CFD Forum | 2 | January 13, 2002 12:32 |
about swirl and vorticity | Junseok Kim | Main CFD Forum | 2 | November 1, 2000 17:46 |
