Array output for design points in workbench
In workbench, I want to change a parameter value (an expression) in CFX and get an array of results for each value of the input parameter.
I have defined design points in workbench but I can't get an array output for each parameter value :confused: So by updating all design points I can have an array output for each design point. How can I do that ? |
Set every output parameter in e.g. cfdpost (after solving once for the 1st dp) and update all design points. After finishing all dp- you can export (via rightClick above the dp-table in wb.2.0--> export data) the dp-table into a csv file.
