-   CFX (https://www.cfd-online.com/Forums/cfx/)
-   -   YPlus Value (https://www.cfd-online.com/Forums/cfx/143401-yplus-value.html)
ENGRTAHIR October 23, 2014 13:21
YPlus Value
I am working on external flow of finned projectile in subsonic range, and use SST model for turbulence. I used Y+ value of 64 and also of 1.5 with hybrid mesh but my results are not compared with experimental. I use reference pressure 1atm and mach number is 0.5.
My inlet intensity is medium
Can anybody help me why its happening
Mason liu October 24, 2014 05:08
I'm not familiar with your case, but you may can try large region of Yplus(i.e. from 0.01-5, name it, 0.01/0.03/0.06/0.09/0.15/0.3/0.6/0.9,,,, or just typical value of those), just for sensitivity analysis, may find a good region of it.
Just try some small Yplus value, see if have significant influence on interested variable.
ENGRTAHIR October 24, 2014 10:52
Thanks for quick reply.
I worked on guided 155 finned projectile.
the servo fin and motor fin are both opened, and i used hybrid mesh for creating grid in ICEM CFD.
Will the hybrid mesh effect CP value. when my Wall Y+ is less than 100 then my results match but when Y+ is 1 then it deviate.
What i do?
also can you help me in mesh making
