November 15, 2014, 12:57 |
modelling volume heat production
Rep Power: 11 |
Hi,how can i model a solid domain with heat production in it's volume?
for example as you know,if we have current in a wire,it will produce heat in it's volume. some tips can be helpful tanks. |
November 16, 2014, 04:08 |
Rep Power: 143 |
Yes, put a source term in the solid region and give it a thermal source.
November 17, 2014, 00:00 |
Rep Power: 11 |
in domain details there are only basic setting,solid models and initialization,where is source?
November 17, 2014, 04:08 |
Rep Power: 143 |
Create a subdomain using the same region locator as you used to define the domain. Subdomains have source term options.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
