Run-time memory allocation error
Old   November 17, 2014, 17:17
Default Run-time memory allocation error
Alex
akalopsis is on a distinguished road
Hey everyone,
I'm running a simple conjugate heat transfer problem (laminar flow) and I keep running into the following error:
| ERROR #001100279 has occurred in subroutine ErrAction.
| Message:
| Master-Partition Nr. 1
| Host computer: EBMM2052-17
| *** Run-time memory allocation error ***
| Not enough free memory is currently available on the system.
| Could not allocate requested memory - exiting!
| Message:
| Slave-Partition Nr. 2
| Message:
| Slave-Partition Nr. 3
| Message:
| Slave-Partition Nr. 4
I found a few posts on here (http://www.cfd-online.com/Forums/cfx...-40gb-ram.html) and other websites from people with similar issues, but I have yet to find a clear solution.
I have 48.0 GB of RAM installed on this PC (Windows 7, 64-bit) and I know that this is sufficient for the simulations that I am running, based on past cases that I have run. I have tried playing around the memory allocation factor/expert parameters, without any success. As you can see from the error, I am currently trying to run the solution using local parallel (4 cores).
Any suggestions regarding this issue would be greatly appreciated.
Thanks,
Alex
akalopsis is offline   Reply With Quote
error #001100279, memory allocation
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
