December 25, 2014, 04:23 |
Axial Fan Timestepsize
Christian
Rep Power: 12 |
Hello and merry christmas,
i want to simulate a rotating axial fan and meassure the velocity and pressure at these two points. The fan is rotating with 1000 1/min and my timestepsize is 0.0005 s (~120 timestep per fan revolution). My boundary conditions are a total pressure inlet(0Pa) and an entrainment outlet at 0Pa( the reference pressure is 0Pa aswell). I think i have a problem about convergence, because i expected something like a sin wave for the velocity over time with the amplitude right when the blade passes. Is my mesh maybe too corse or my timestepsize too large? Which turbulence model would you suggest? Rans or les approach? Best Regards, Chris |
December 25, 2014, 16:02 |
Rep Power: 143 |
December 25, 2014, 16:11 |
Christian
Rep Power: 12 |
Hi Glenn,
at the moment im working through the faq steps, thanks! Will you think i can meet the results i expect with the rans approach (with a small timestep) or do you think i need to do it with les? |
December 25, 2014, 16:23 |
Rep Power: 143 |
If the fan is operating near the design point (that is, attached flow) then RANS is usually fine. You usually need to consider LES as you get into off-design point operation where there are large separations.
Your mesh looks quite coarse as well. Make sure you do a good mesh sensitivity check as well. |
January 7, 2015, 02:53 |
Rep Power: 14 |
Just one more remark...as I saw n our attached images...you just simulated 0.5 s of time. I would expect, that your solution is still stuck somewhere between your intialisation and the "real" solution.
If you started with a motionless initialisation, I would expect that it takes more than 0.5 s before reaching the point where the whole domain reaches a "steady point" (knowing that a steady point for this kind of problem is not existing, but at least a periodically returning event). And the image of your mesh is showing the whole domain or just a dteail of it? If it is showing your whole domain, then your boundaries (especially top and bottom) seem much too close to your fan for me. Therefore a negative influence of the boundary on the solution and vice versa could not be excluded...possibly leading to the fact that you don't see a periodic sin wave |
January 7, 2015, 05:13 |
Christian
Rep Power: 12 |
Thank you for your anwsers!
I think the first thing i should do is remeshing and changing the domain size a bit. Do you think it will work with just thin walls as blades, or do i need the blade profile? |
January 7, 2015, 05:25 |
Rep Power: 14 |
What do you mean with thin walls instead of the blade profile?
If you don't take the real shape of your fan, then you will get a different flow field.... |
January 7, 2015, 05:32 |
Christian
Rep Power: 12 |
Im more interessted in a generic chase than in the real flow for a given velocity. Do you think it will give me the assumed results( like a sin wave for velocity) ?
January 7, 2015, 06:09 |
#9 |
Rep Power: 143 |
Your mesh is too coarse to resolve much at all. Also you have not run it long enough, it is still going through the initial transients.
January 7, 2015, 06:13 |
#10 |
Christian
Rep Power: 12 |
January 7, 2015, 06:19 |
#11 | |
Mr CFD
Rep Power: 14 |
http://www.cfd-online.com/Forums/cfx...date-time.html |
January 7, 2015, 06:25 |
#12 |
Rep Power: 143 |
Thin blades will be harder to simulate because they always have a separation at the leading edge. Separations are hard to simulate. So an airfoil shape operating near its design point will have attached flow over the whole length and will be much easier and more accurate.
January 7, 2015, 06:44 |
#13 |
Christian
Rep Power: 12 |
Is there any generic axial fan geometry available online?
January 7, 2015, 17:51 |
#14 |
Rep Power: 143 |
No idea, try google.
January 10, 2015, 04:08 |
#15 |
Christian
Rep Power: 12 |
i simplified the geometry to just one small part of one blade.
The steady state simulation works really well, but now i want to change to transient because i want to simulate one blade passing like you see below. From: To: I know how to transform the domain location by hand, but how can i tell the solver to do that? Got it! : Transient Stator Rotator :-) Last edited by Chris_321; January 11, 2015 at 15:32. |
Display Modes | |
Simulation of Axial Fan Flow using A Momentum Source Subdomain | Liam | CFX | 28 | July 16, 2013 08:24 |
Axial fan or blower cooling a hot object with recirculation | mariconeagles96 | CFX | 4 | April 18, 2012 08:41 |
urgent pressure condition for axial flow fan | VIPUL | FLUENT | 0 | October 24, 2008 02:01 |
Axial Fan | Russ | FLUENT | 8 | July 7, 2006 13:59 |
axial flow in counter rotating ducted fan | Vishu | FLUENT | 4 | January 13, 2004 17:52 |
