Propeller cavitation with non condensable gas(first constant property then ideal gas) |
February 9, 2015, 04:47 |
Behrooz Jamshidi
Hi
Im modeling cavitation on a propeller with a constant volume fraction of air.After a procedure I got converged solution with reasonable results. Now when I change air to ideal gas (with isothermal heat transfer) or define an expression for variable density with the previous run as initial value, I get overflow error on the first time step. B.C:velocity inlet and opening with static pressure. tstep=0.0001 Ive also decreased time step to 10e-9 which didnt help. Decreasing relaxation factors caused overflow happen later(on 6th tstep) Any idea? |
February 9, 2015, 05:23 |
Rep Power: 143 |
I have attempted a similar simulation previously and never got it to work either. I never looked into it very hard, but you can expect to have a hard time getting this to converge (as you have found). I can only recommend trying some of the solver expert parameters and other solver settings and see if they help, otherwise contact ANSYS and see if they can help you.
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Non condensable gas mas fraction for CAVITATION | Xa | Main CFD Forum | 0 | April 2, 2008 11:28 |
question about ideal gas thermal flow | yong | Main CFD Forum | 0 | January 6, 2006 23:58 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
