Error #001100279
Old   October 10, 2009, 08:35
Default Error #001100279
Bharath kumar
bharath is on a distinguished road
hi to all,
can anybody help me to resolve this error.thanks in advance
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| read_compressed_dataarray: offset 4707459271968572714 too large f- |
| or integer,
would be written as 1145980202. Possibly compressed |
| chunk >2Gb. |
| Message: |
| iocnt: read data failed |
| Message: |
| APPEND_TRACK_VAR Failed to read data |
| WHAT=G/TRACK_TOPOL_PT1 WHERE=ZN1- |
| Message: |
| write_index: warning: new index not at end of file, file may be b- |
| ad |
| Writing crash recovery file |
| Message: |
| Stopped in routine APPEND_TRACK_VAR |
| An error has occurred in cfx5solve: |
| The ANSYS CFX solver exited with return code 1. |
End of solution stage.
| The following transient and backup files written by the ANSYS CFX |
| solver have been saved in the directory |
| /home/CFX/Bharath/Others/Wang/run/cyclone_29.9_026: |
| 200.trn |
| Error reported by IO module: create_indextable: stored index is |
| wrong: missing start tag |
| Error reported by IO module: iif_open: unable to read the stored |
| index, attempting to rebuild it |
| Error reported by IO module: recreate_indextable: warning: file |
| was not closed correctly, data may be inconsistent |
| Error reported by IO module: write_index: warning: new index not |
| at end of file, file may be bad |
| The results from this run of the ANSYS CFX Solver have been |
| written to /home/CFX/Bharath/Others/Wang/run/cyclone_29.9_026.res |
| Warning! |
| The ANSYS CFX Solver has written a crash recovery file. This file |
| has been saved as |
| /home/CFX/Bharath/Others/Wang/run/cyclone_29.9_026.res.err and may |
| be an aid to diagnosing the problem or restarting the run. More |
| details should be available in the solver output section of the |
| output file. |
| The following user files have been saved in the directory |
| PT1.trk |
This run of the ANSYS CFX Solver has finished.
bharath is offline   Reply With Quote
Old   October 11, 2009, 05:09
Seems pretty obvious to me. The file you are trying to write, I assume a particle tracking file is very large. Try recording less particle tracks or moving to a 64 bit OS.
Old   October 11, 2009, 08:00
Bharath kumar
thanks glenn,
i will try your solution. but am trying to simulate only (400 particles/sec) whether it cause problem and now the simulation time is only (.25sec)
Old   October 11, 2009, 17:38
The number of points in the tracking file = average number of points * timestep * residence time. Reduce any of these numbers and you will reduce the size of the particle tracks file.
Old   October 12, 2009, 11:36
Bharath kumar
thanks glenn.
could you explain me little bit more. i couldn't able to reduce the time step and
residence time is not in my hands.then what i can do now?
Old   October 12, 2009, 18:16
Isn't that obvious? The only thing left is to reduce the number of particles.
Old   October 18, 2009, 07:09
??? What's to say? Isn't that equation obvious?
Old   March 25, 2015, 04:49
Przemek
gaza is on a distinguished road
Hi Glen
I have got such message:
| ad
but my simulation is running. Is it an error or everything is ok?
best regards
pblasiak
gaza is offline   Reply With Quote
Old   March 25, 2015, 04:51
Przemek
and one more thing
I had not have a res fike only trn. So I changed the extension from trn to res and used this file as initial condition.
best regards
pblasiak
Old   March 25, 2015, 05:31
I would be suspicious that your output file (either output, results or particle file) is corrupt and will be unreadable.
I would save a backup file and check all the key output files to see if they are OK.
