PPD & PMV value
I'ma new user to CFX ANSYS 15.0. I did a comparison between simulation on occupied room thermal comfort study. I have a few problem, 1.How can I calculate the PPD & PMV? 2. So far I can get the MRT calculation by the comfort factor macros. Yet it can't be displayed in CFX-Pro on the surface. Please do advise. Thank you. |
Please, no jargon. What is PPD, PMV and MRT?
What do you mean by CFX-Pro? |
MRT (Mean Radiant Temperature)
PMV (Predicted Mean Vote) PPD (Predicted Percentage of Dissatisfied) I already followed the guide "A CFD-Post macro is available for this purpose, and is accessed using the Macro Calculator from the Tools menu". In the solution part, I plot the MRT contour on the plane but the results is failed. But when the calculator calculate it showed a value for the plane. By means, in the legend of MRT, contour for T=289K is yellow color but when I plot on the surface, the yellow color did not appear. I have found comfort-factors.ccl and usr_pmvppd.F file but I have failed here. The CFD-Pro is a typo error. Please do advice. Thanks |
Hello Tanty Ali,
I am also working on a similar project. Since you have figure out how to plot MRT in ANSYS. Could you please do me a favor and tell me, what model does ANSYS CFX uses to calculate mean radiant temperature and what is the equation for it? As far as I know it doesn't use the conventional ASHRAE method to determine the MRT based on surrounding wall temperature. I would really appreciate your help. I will have to plot PMV and PPD but I am now in very initial stage and not really familiar with ANSYS CFX. So at first I just wanted to know the equation of MRT used by CFX. Regards!! |
Hi Madeinspace,
I haven't solved yet the MRT, PPD and PMV issues. Maybe because i can't access to fortran compiler. Sorry for this.I have changed the simulation to Flow Simulation using Solidwork cos I'm running out of time for submission. Regards. |
Yes,
Flow simulation is very easy with powerful GUI. I have also been using Flow Simulation but been advised to change to CFX. So I was trying to give it a try. Thanks anyway. |
Mean Radiant temperature
Did anyone of you how to find mean radiant temperature in ansys fluent.Please tell I am working on thermal comfort in car cabins.
