isolated fluid filled container cooling by water |
May 5, 2015, 05:57 |
bcm
I want to analyze pressurised gas filled solid container cooled by water flow inside CFX workbench. I have specified two fluid,solid zone. In gas fluid is air and other fluid is water. Both the fluid is with isolated physics. The water zone is having in/outlet. the ref pr. is 1.013e5Pa. Both gas and solid is having source of heat. On CFD-Post, the pr. variation is there for water but for gas zone it is zero with local pressure.however, temp. variation is there inside gas. Although on heat, the pressure of gas should increase. why I can't see pressure variation inside gas? Any special setting is there?
Fluid-Solid Interface Settings for a Rotating Water Container | r.mojtaba | CFX | 4 | October 14, 2013 19:01 |
ansys cfx solver exit with return code 1!!!!! | mhabibnia | CFX | 7 | August 19, 2013 03:53 |
Error (2 isolated fluid regions) with an englobing domain | syens | CFX | 2 | January 12, 2012 10:55 |
Regarding isolated fluid region | Tushar | CFX | 1 | March 5, 2008 08:26 |
cooling fluid flow | susan burke | FLUENT | 1 | November 24, 2003 10:22 |
