Home > Forums > CFX
Acoustic waves and Courant number
Old   May 11, 2015, 01:33
Default Acoustic waves and Courant number
Costin Ruja
costinruja is on a distinguished road
Send a message via Yahoo to costinruja
Good morning !
After some fiddling on my own, i would appreciate your comments on the topic.
The problem is quite straightforward.I have a transient Ahmed body simulation, about 5 mil. elements and 1.3 mil nodes.I would like to do some aeroacoustics on it just for personal training and for the fun of it.
The first thing I know is that I want it to run SAS-SST with central differentiating scheme to better capture the buffeting wake.Then i got stuck at choosing the timestep size. CFX being an implicit solver I know I don't have to go with Courant number=1 for the flow, but is this also true with the acoustic wave (sound speed=340m/s) ?
Also i expected something like concentric pressure waves emmanating from the back side of the ahmed body (where flow separation takes place), but I don't see the yet.
I set up a pressure monitor point, and i think it captures quite nicely some quasy-sinusoidal wave.Is it correct to assume this is the acoustic pressure and just do some FFT and dB conversion on it to find the SPL ?
Since I'm interested only in finding the near-field SPL (only a meter a way or so), only with CFX, and not coupled with some third party tool like LMS Sysnoise or MSC Actran what is the best approach to this problem ?
Thanks !
costinruja is offline   Reply With Quote
Old   May 11, 2015, 03:16
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
Yes, as CFX is an implicit solver the time step size is linked to time resolution accuracy, not Courant number. So do a time step sensitivity study and see how fine the time step needs to be to capture the acoustic waves to an accuracy you are happy with.
Just checking - are you running a compressible fluid simulation? You won't get pressure waves if your fluid is incompressible.
Yes, you can do a SPL calculation from the pressure monitor point if you are only interested int he near field SPL. Keep in mind reflections off the outer boundary - this will distort the result if not managed properly.
Old   May 11, 2015, 03:23
Costin Ruja
Yes, I did model the air as compressible (air ideal gas) and total energy option turned on.
I guess i'll have to wait for some good number of hours to see the flow develop and begin to oscillate.
Thanks a bunch Glenn !
Old   May 11, 2015, 05:54
As a starting point I would guess a time step of 1/10 of the highest frequency you will be analysing. It will probably require a finer time step than that, but it is a starting point.
Old   May 11, 2015, 10:26
Costin Ruja
I'm currently running with a timestep of 4e-4s as found by the solver to give a RMS Courant of 1, so according to your 1/10 rule, I should get well resolved waves up to 250Hz.For now, i'm letting it solve at this rate, although.
Thread Tools
Trackbacks are On
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
variable time step:setting global courant number Cedric FLUENT 0 July 28, 2005 09:14
About Courant (CFL) number Jason Main CFD Forum 2 March 17, 2003 12:11
Riemann problem with two strong rarefactin waves Alexey FLUENT 1 June 20, 2001 13:09
Riemann problem with two strong rarefaction waves Alexey CD-adapco 1 June 19, 2001 16:55
