How can I detect cavitation presence while the simulation is still running?
Hello
I need to design the blades for an axial pump whose flow rate, head and RPM is known. Obviously the pump should not caviate. :p My question is double: 1) Let's suppose I could "probe" the static pressure on the most critical region of the pump blade and that I could monitor this variable during the simulation process. At what residual level (or at what convergence level) do the local static pressure (in case of cavitation of course) become reliable? I mean: should I wait to reach 1E-7 MAX residual or 1E-4 is enough for this kind of information? 2) The blade grid has been created with TGrid. Is there a way I could DYNAMICALLY monitor a variable (like "static pressure" in the most critical region of the blade) during the simulation, so that if I see that the value gets stable (and near to 2500 Pa) I can say: ok, there's cavitation, I need to modify the blades, let's stop the simulation! I hope I've been "understandable". If not, then please feel free to ask and I'll try to be more clear. As Always, thanks so much for your help!!! |
1) the convergence required to achieve a reliable answer is obviously different for different applications. For some people 1% error could be all they can tolerance, but for others being off by 20% is OK. On top of that, a given level of residual does not equate to a universal accuracy number - the relationship between accuracy and residuals is not fixed.
This is a long way of saying you should determine the level of residual required for your application and your accuracy requirement. Do a sweep of convergence tolerance and monitor values of importance to you - then you can select the tolerance which gives you the accuracy you require. 2) Use a monitor point. You could put it at a defined point like you suggest, or you could just use minVal(p)@domain and it will return the minimum pressure in the entire domain. |
Thanks so much for your super useful answer. I understand that residuals and convergence are always delicate concepts. Can you tell me something more about the monitor point? How can I locate it? It would be perfect for my case. Thanks again
Monitor points are described in the documentation and used in the tutorial examples.
Have a look on the output tab in CFX-Pre. |
Ok, thanks. I'm checking out right now. Thank again!!! :)
I used the monitor points as a probe in given locations on the blade, as you suggested. Everything works so nice! Thanks, ghorrocks, you saved my life! :)
