June 3, 2015, 10:52 |
Running CFX on 512 cores in the cloud
I am running CFX on 64 A8 machines (=512 cores) on Microsoft Azure as follows: \\hsransys.file.core.windows.net\main\apps\ANSYS Inc\v150\CFX\bin\cfx5solve" -def "%def_file%" -chdir "%workdirpath%" -start-method MSMPI2 -part %num_of_partitions% and get the following error: job aborted: [ranks] message [0-191] terminated [192] fatal error Fatal error in PMPI_Bcast: Other MPI error, error stack: MPI_Bcast(buf=0x00007FF699BAC240, count=5000, MPI_PACKED, root=0, MPI_COMM_WORLD) failed [ch3:nd] Send to 172.16.1.213:7 completed in error with 0xc00000b5 [193-511] terminated ---- error analysis ----- [192] on 10.10.13.159 mpi has detected a fatal error and aborted \\hsransys.file.core.windows.net\main\apps\ANSYS Inc\v150\CFX\bin\cfx5remote.exe ---- error analysis ----- We assume that the after MPI BROADCAST took too long and there should be a timeout parameter in the MPI stack that can be tuned so that the time needed for MPI Packets to come back can be extended? Any suggestions how to set it up will be helpful. |
[ICEM] Simple pipe meshing - problems with y+ in CFX | Keizers | ANSYS Meshing & Geometry | 23 | January 15, 2015 08:00 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
Cloud Interpolation in CFX 5 | Jens | CFX | 0 | September 9, 2003 06:35 |
Running CFX on a cluster | jvk | CFX | 9 | September 19, 2002 22:22 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
