Monitor every iteration in transient simulation |
June 8, 2015, 22:28 |
NC
Rep Power: 11 |
Normally the monitor for a transient run shows the values for every iteration in a time step. (The plots are jagged as the variables jump upon entering a time step and then approach convergence.) In the latest run, however, the monitor appears to show only the result of the last iteration of each time step. How can I switch between the two modes? Thanks.
June 9, 2015, 02:09 |
Lance
Rep Power: 22 |
In the monitor tab you have the option to 'monitor coefficient loop convergence'. If it is checked you will see the monitor values for all coefficient loops.
June 10, 2015, 09:53 |
NC
Rep Power: 11 |
Thanks. Curious how that option is in the solver setup rather than the monitor, isn't it?
June 10, 2015, 10:48 |
Rep Power: 32 |
If it is not set, it is not written for monitoring.
The setting must be upstream of the data being available, I guess |
monitor, transient analysis |
Regarding error in Transient simulation | Thermal_engg | FLUENT | 2 | October 26, 2016 01:32 |
Exporting data of transient simulation DURING a simulation, at user locations ? | Milan2013 | CFX | 0 | April 18, 2014 03:47 |
Transient simulation of intake manifold | Santoshnalanagula | FLUENT | 0 | January 1, 2014 07:32 |
the problem of my transient simulation "Floating point exception: Overflow " | alloveyou | CFX | 15 | November 22, 2012 11:14 |
Resume Transient simulation | HMR | CFX | 1 | June 28, 2011 21:13 |
