How to create liquid gaseous interaction in the same container? |
September 25, 2010, 02:11 |
Hari Krishnan Kumar
Rep Power: 15 |
My problem consists of a closed tank with half filled liquid with remaining filled with pressurised air!! tank consists of one baffle plate to reduce the turbulence. the inlet s going to be a pipe attached to the tank! so how to define the liquid and gaseous region separetly in the tank?
and also wat kind of turbulence model can be given if the liquid is having reynolds no of 13000? |
September 25, 2010, 13:57 |
Rep Power: 17 |
In 12.1 one define your air and your water as two continuos fluids. Acitvate free surface model.
K-eps should be most stable, SST should work also. |
September 25, 2010, 19:24 |
Rep Power: 143 |
Use the SST turbulence model for all turbulence modelling unless you have a good reason not to. My opinion is SST is the baseline turbulence model now and has superseded the k-e model.
June 14, 2015, 06:39 |
#4 | |
Shane
Rep Power: 16 |
Hi Ghorrocks I inject a pressurized Gaseous Fluid in to Pressurized Tank Filled with Hot Viscous Fluid". Should I choose SST or K-E ? However due to high glow rates, my system is acts as fluidised system. System has multiple flow rate regions(orifice plates). In some regions flow rates are low while in other pretty high(orifice plates) These orifice plates are killing me. 99% of meshing is there. Also some time due to over heating Fluent Drops or some time due to over Reverse Flow. But it is all fun doing thing new. ? |
June 14, 2015, 06:54 |
#5 | |
Rep Power: 143 |
Let me quote my previous post:
If zillions of oriface plates are causing havoc then replace them with momentum source terms. This is much simpler and often more accurate. |
Display Modes | |
Actuator disk model | audrich | FLUENT | 0 | September 21, 2009 07:06 |
Where's the singularity/mesh flaw? | audrich | FLUENT | 3 | August 4, 2009 01:07 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Liquid solid interaction and GUI question | danvica | OpenFOAM Pre-Processing | 0 | December 6, 2007 04:34 |
Liquid water, gaseous water and another gas | Andy | FLUENT | 1 | May 22, 2006 08:51 |
