Real Gas Properties
Like Tree1Likes
  • 1 Post By Cafard
Old   July 15, 2003, 09:01
Default Real Gas Properties
mbga8ejf
Hi
Does anyone know how i select the refrigerant r134a as the working fluid?
also does anyone have RGP tables for other refrigerants?
Ed
Old   July 15, 2003, 10:23
Default Re: Real Gas Properties
Min
Please go to "Fluids Edite" creating new material.
Old   July 16, 2003, 02:00
Neale
Ed,
Open the materials selector. Hit the little "open folder" box on the right side. Load up the file "MATERIALS-redkw.ccl". r134a is one of the materials in that file.
Ask your support person if you need a pressure and temperature range for r134a that the RGP table does not cover.
Refrigerant RGP tables in CFX-5 are also available if you purchase a copy of REFPROP from NIST. If you do that then you can call your support rep and they will gladly supply you with whatever RGP table you need for any refrigerant in the REFPROP library.
You can also, if you like, generate your own RGP file if you decide on an equation of state, constituitive relationship and saturation curve data. The format of the file is documented in the Real Fluids section of the solver modelling documentation.
Neale
Old   June 12, 2014, 04:22
Cafard
Cafard is on a distinguished road
hello,Neale
i have NIST RefProp program
and now i want to use CFX to simulate supercritical CO2
so i need to import a real CO2 properity to create a new material
but i can't generate a RGP file by RefProp
how did you do that?
munjal likes this.
Cafard is offline   Reply With Quote
Old   September 11, 2014, 12:33
Default Real Gas Properties R245fa
Angie Espinosa
ANGIE is on a distinguished road
Hi!
I have NIST RefProp program, and now i want to use CFX to simulate R245fa,
so I need to import a real R245fa properity to create a new material
but I can't generate a RGP file by RefProp.
How did you do that?
ANGIE is offline   Reply With Quote
Old   June 15, 2015, 06:00
Smile
lixiao
icare2013 is on a distinguished road
Originally Posted by ANGIE View Post
Hi!
Did you solve the problem? I have the same situation now. Could you tell me how to solve it?
Thanks!
icare2013 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
