Gas-liquid pipe flow
Hi guys, im new in CFX and im trying to simulate a gas liquid multiphase flow but im getting weird results, i just want to be able to identify some horizontal pipe flow patterns (wave, stratified, etc) but i reallt dont know very well how to set the bc and multiphase models, i have read some tutorial and i have done this.
i set a simple horizontal pipe 3 m lenght and 0.20 m diameter at inlet i set 0.5 of gas and 0.5 of water 1 m/s both a simple outlet with av pressure 0 atm im starting with laminar flow, both continuos phases, inhomogeneuos. fluid pair with mixing model, and drag coefficient. i just want to know what best settings i have to usea to model stratified flow as i run the model i get some waves but at some time i have "picks" in convergence and i see like suddenly "explosions" in the flow. i know i have alotof things wrong. In simple words what a have to do to set a stable model. |
For free surface flows - they are quite sensitive to time step size. I would recommend you use adaptive time stepping so it can automatically find a good time step.
Use adaptive time stepping, homing in on 3-5 coeff loops per iteration. Make sure the max and min time step size are wide enough that you do not hit them, and give it a sensible starting time step size. |
thanks
thanks glenn ill try that today.
Curious question for the knowledgeable:
Can you run this problem in steady state, with a small physical time step (e.g. t = 0.001 s) for 10000 iterations? This will give you a pseudo simulation time of 0.001 * 10000 = 10 s. Then use the steady state results as the initial guess for a transient run, but setting the initial start time as 10 s? Thanks |
