Continuity Convergence Problem in CFX
5 Attachment(s)
Hello
I am simulating a relatively simple case in CFX. A flow in the inlet duct of a compressor is being modelled to study the total pressure loss. I am using the following settings: -Steady state - Air as Ideal gas, Reference Pressure 0 Pa, Heat Transfer as Total Energy and Turbulence as SST Model with wall y+ around 1(I am using good quality Structured Mesh with wall y+ around 1) - At Inlet Total Pressure is used as Bounday condition with 34667 Pa and Total temperature 243k. -At Outlet Static Pressure is used with 28000 Pa. -Advection and Turbulence Numerics with High Resolution and Convergence criteria is set as 0.00005 for all the equations. Initially a run was performed at Physical Time Scale of 0.001 for 350 iterations and I was expecting a good convergence considering the simplicity of flow and good quality of mesh but the convergence of Continuity Equation is not so good as shown by Residuals in the pic1. Then I considered to perform Time Scale study for this case while doubling and reducing the time scale half(1/2) i.e 0.002 and 0.0005 but that didn't seem to help much. These cases are only performed for just 100 iterations. Residuals for continuity equation are not going beyond 10-4 as shown in the pic2 and pic3. Then I further considered increasing the Time scale(as increase in time scale helps in faster convergence) to 0.01. This was the biggest Time scale at was solution was stable, further increment resulted in the divergence of the solution but even this big time scale does not aid in acheiving the good convergence for continuity residuals as shown in pic4. This case was also performed for 100 iterations. So time scale of 0.01 give me a starting guess(as this was the biggest time scale at which solution was stable) to perform further simulations using Step Function for time scale study. 0.01 time scale was used for 1st 20 iterations and then it was increased using step function with some factor and at the end for last 20 iterations time scale was 0.12 was reached(step function). A similar 2nd step function was used with 0.01 for 1st 20 iterations and increment was such that for the last 20 iterations a time scale of 0.2 was used. In these 2 cases atleast I was expecting some better convergence but only to my fustration, not much was acheived. The pics for these two cases are pic5 and pic6. Can anybody tell me what can be the reason behined this. Large time scales are not helping to acheiving the good convergence(let's leave the accuracy for time being aside). Even step functions with large time scales at the end of iterations didn't help. I am open to any suggestions and will share the further details if somebody needs in helping. Any help is appreciated. |
1 Attachment(s)
pic6 for 2nd step function.
I am a bit confused about your interpretation of the physical timescale:
As an advice to understand convergence issues, please do the following:
Hope the above helps, |
