July 5, 2015, 11:31 |
CFD-Post: Time integration
Daniel
Rep Power: 21 |
Hello to all,
I have just started to use CFD-Post to post-process simulation's results from Ansys Fluent. I have a question about time integration in CFD-Post. Is it possible to perform time integration in CFD-Post? Regards |
July 5, 2015, 18:31 |
Rep Power: 143 |
What type of time integration? What do you want to integrate?
I usually export that sort of data from CFX and do time integrations in a mathematical application like matlab/python/excel. |
July 6, 2015, 05:05 |
#3 | |
Daniel
Rep Power: 21 |
To do so, I need to integrate wall shear stress over time! Is there anyway to do the integration directly in the CFD-Post? best wishes |
July 6, 2015, 06:17 |
Rep Power: 143 |
This is far better done in the solver. This is because you then can use every time step for the time integration, whereas in the post processor you can only use the time steps you have results files for.
So I would recommend you rerun the simulation with a monitor point outputting the wall shear stress at the point (or averaged or whatever) you want. Then you can easily do the equation you describe in a mathematical package. If it is not possible to rerun the simulation then all you can do is export the wall shear stress for the time steps you have data for. Then you again do the time integration in a mathematical package. This is far less accurate as you will not have as good time resolution. |
July 6, 2015, 16:45 |
#5 | |
Daniel
Rep Power: 21 |
So, I have to extract the shear stress for every single case and data manually and do the integration with another software? |
July 6, 2015, 18:46 |
Rep Power: 143 |
You should have planned a bit better before the simulations started then
Yes, extract the data from CFD-Post and export it somewhere. You can use the CFD-Post session files or other scripting capabilities to make this easier. Then do the time integration in a another software. |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Rendering Time - CFD Post | aalansari | Visualization & Post-Processing | 0 | May 1, 2015 15:41 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
