July 7, 2015, 11:41 |
homogeneous binary mixture
niru
Rep Power: 14 |
I want to model the vaporization of liquid methane to methane vapor. As and when heat is methane liquid, it should get converted to vapor.
If I chose the peng robinson wet refrigerant of methane ch4vl (homogeneous binary mixture) , will I be able to model this phenomenon. Or should I add, CH4 vapor seperately and CH4 liquid separately. Which material should I chose? |
July 7, 2015, 18:23 |
Rep Power: 32 |
You load the 3 materials: CH4vl, CH4l, CH4v.
You add fluid to your domain, and select the binary mixture for the material in the fluid, i.e. CH4vl. Summary: you are modeling the binary mixture as a fluid in the domain. For thermodynamic calculations, the software needs to know the information of each thermodynamic state separately. Hope the above helps, |
binary mixture, ch4 |
[Resolved] GPU on Fluent | Daveo643 | FLUENT | 4 | March 7, 2018 08:02 |
Error in solution using "Grid Interface" | agustinvo | FLUENT | 4 | January 20, 2015 12:03 |
how to set Boussinesq model for homogeneous binary mixture | richard2000 | CFX | 3 | September 14, 2010 03:04 |
Error to re-open fluent case file | J.Gimbun | FLUENT | 0 | April 27, 2006 08:42 |
Sliding mesh error | Karl Kevala | FLUENT | 4 | February 21, 2001 15:52 |
